fuel issues
(In Topic #86690)
fuel issues
has it always run like this? got gradualy worse?
i'd check co first. 3mm allen key job.
FUEL PUMP
wooders said
try the cheap and easy checks first.
note. TRY THE CHEAP EASY CHECKS FIRST
it sounds like the new pump is either fitted incorrectly or not working. check the wiring or maybe retro fit the old pump. it does sound like fuel starvation but could be electrical. fuel pressure can be affected by faulty metering head or wur. could however just be running lean.
could be weak spark, have you checked plugs? they should indicate if you're running too rich or lean. checked cap? leads?
FUEL PUMP
I TOLD YOU SO
let us know how you get on and i will keep my fingers crossed for you.
FUEL PUMP
FUEL PUMP
1982 Non Sunroof Black 1600 GTI
2003 MKIV Golf PD150 GT TDI
