fuel issues
(In Topic #86690)
fuel issues
Hello guys just thought id pick your brains for suggestions.On my way to the beach saturday full throttle on a bumpy b road in fifth, cars flying; get held up behind a lovely old lady and go to safely pass to find it kangarooing as soon as i apply any throttle.My guess was the bumpy road my have thrown some rust from the tank into the system. AA man reckons the fuel pumps had it which sounds like a good enough suggestion as its very noisy and feels a bit rough when running. Basically it idles fine and soon as you give it throttle it coughs and splutters and is blatently starved of fuel,is there a filter in the pump itself(83 gti tintop).Any suggestion to what i could look for would be great.Thanks.
try the cheap and easy checks first.
has it always run like this? got gradualy worse?
i'd check co first. 3mm allen key job.
FUEL PUMP
Bit the bullet this morning and purchased a new bosch fuel pump today as im pretty convinced this is my trouble.Fitted it and now the pump wont prime and car wont fire at all just turns over
I have bridged the relay and can feel it click at the relay and at the pump it just wont prime or fire.Fuse no5 is ok too.HELP.Thanks.
note. TRY THE CHEAP EASY CHECKS FIRST
it sounds like the new pump is either fitted incorrectly or not working. check the wiring or maybe retro fit the old pump. it does sound like fuel starvation but could be electrical. fuel pressure can be affected by faulty metering head or wur. could however just be running lean.
could be weak spark, have you checked plugs? they should indicate if you're running too rich or lean. checked cap? leads?
FUEL PUMP
I've wired the battery directly to the pump and established i drove 70 miles and forked out the best part of a hundred quid for a pump that dont work
Gutted.Oh well,will get onto them and get a replacement sorted and try again.Wooders its true what you say about the checking the easy stuff first but im 99% sure its the pump and all the plugs and leads etc. are all pretty much new after engine conversion. Prowlers injector test looks very helpfull but again im sure its the pump and dont really want to go to that trouble until i got the new pump fitted;but i will do this soon once pump is sorted.Thanks for your help guys!!! Appreciate it.I'll let you know if the pump does the trick and if not you can both say i told you so
ops: .Cheers.
i'll do it now, so it's out of the way.
I TOLD YOU SO
let us know how you get on and i will keep my fingers crossed for you.
I TOLD YOU SO
FUEL PUMP
Thats funny,i was gonna put in my post you can say i told you so in caps lock but it seems you have done it anyway
.I WILL take great pleasure in informing you it was the fuel pump and when i do;i too will use caps lock :mrgreen: Time will tell!!!Watch this space wooders.
nothing would please me more, for you to be correct. only thinking of your efforts and wallet.
FUEL PUMP
FAO WOODERS;IT WAS THE PUMP :wink: I TOLD YOU SO 8) RUNS SWEET NOW!!
i diggin this thread, terrible one you description of your og problem sounds like what my cars going through at the mo
….i think i need to do prowlers fuel pump test but can't seem to find it where is that?@? for now i'll do the bridging test over where the relay should be and see what reselts i get
1982 Non Sunroof Black 1600 GTI
2003 MKIV Golf PD150 GT TDI
