Fuel gushing out of filler pipe
(In Topic #101531)
Any ideas? :dontknow:
Dein
Pete :wink:
:dontknow:
Dein
Dein
Ginger said
The road has quite a camber, that is the bottom of doors hit the pavement if opened wide. Still, it doesn't seem extreme. Must have brimmed it then. Oh well Live and learn.
Dein
The other possibility is the fuel you filled up with, was very cold (in an underground storage tank?) and then it heated up and expanded once in your tank.
Basically, don't brim the tank, unless you're about to set off on a long drive (so you'd use up the couple of litres or so in the filler neck).
Thanks Paul
