Fuel filler neck
(In Topic #123805)
Fuel filler neck
I bought one that was a hadrians panels item and the fit is diabolical, it's not even worth its weight in scrap metal!
I remember crazyquiff listed filler necks that were zinc plated / steel anodised and they were stated as having been made by the oe supplier but thee are no longer listed on his website.
Does anyone know anywhere that sells filler necks that actually fit properly?
Cheers,
Juan
What car is it? Tin top or cabrio?
I'm looking for a cabby one at present.
Projekt Frustration :
White 1991 Clipper. Lowered over polished zender rims, Single 40 dellorto on lynx manifold, kent cam, full stainless 'zorst / manifold, powerflex bushed and braced. Not the fastest car, but sounds super nice!
Still going after 12 years… never said it was a quick fix! Time is not my friend.
I did buy a pattern one, the holes didn't line up, the filler face would not sit flat against the inside of the panel and the other end pointed to the ground too much which meant it need to be bent and bashed around just to be vaguely put in place.
The pattern filler necks are absolute crap!
I have contacted ATP panels in Germany to ask if their filler necks fit properly (asked if they can guarantee this to me) but I suspect they probably just get them from the same factory as Hadrian panels
vw list "171 201 129 N" as still being available as a genuine part, does anyone know what this fits?
peeriehutchie said
i have a spare second hand one if you want ?
You have pm
could someone tell me if the filler neck is the same on the 3 door tin top as on the 5 door tin top
thanks in advance
thats what i thought but i just wanted to be sure
Fuel Filler Pipe
