Fuel Economy Question
(In Topic #76458)
My Mk1, 1.8 8v with supersprint exhaust and k&N is currently doing about 200 miles for ?35 of premium unleaded, which seems a bit bad to me. Working out the averages, with a mix of town and motorway driving, thats costing me about 18p a mile? Is this right, or have I got a problem somewhere? If so, where do I start?
Anthony
I measured mine just the once (tank-tank fill), on a motorway trip, and I achieved 36mpg which I'm well pleased with, compared to 20-25mpg for my other cars! These days, I hardly ever use the car and I've been running it a lot, stood still, to tune it, so its not really worth trying to work it out.
DubPartz
Re: Fuel Economy Question
Anthony
CO percentage. It should be 1-2%. Its adjusted using a long 3mm allen key into the screw in the fuel distributor, once you've done it no doubt you'll need to readjust the idle speed too (7mm, hard to get to on rear of throttle body, near scuttle panel).
cheers for the wheels anton :mrgreen:
muttley racing ftmfw
MK1 Mars Red Campaign
No worries on those wheels mate, hope you do alright on sunday.
If i adjust the mix, how do i measure what sort of mix ive got? As you can probably tell, im not very mechanicaly minded but do want to learn.
In case anyone does have any other ideas, I always fill her right up, and try not to go too much in to the red, so I would say on that basis im averaging approx 20mpg!
Cheers for the help guys.
Ant
You'd need a gas analyser. I've had trouble with them in the past. What I did this time is connected it to the battery and left it for an hour, then the readings made sense.
The fuel consumption will depend a lot on whether you are doing lots of round town driving with lots of starts from cold or long motorway journeys at steady speeds. My auto, which will be worse than a manual, currently does about 25 mpg around town, which I'm not too HP with. My previous golf, a 1.8 8v Mk2 that I did lots of long trips in, used to do about 36mpg 8) giving me well over 400 miles out of a tank.
Hope this helps
Ian
'89 Clipper Auto and '92 GTI Cabby
would you recomend any particuler gas analyser?
Maybe I just have a dodgy one?
Hope this helps
Ian
Thats why im querying it, I had a mk2 8v gti before I got the mk1, same sort of driving, but averaging at least 30mpg! Oh well, best get the tools out tommorow, hopefully it will be dry!
the place was bears garage services birmingham :wink:
1983 lhasa green mk1 1.8 gti
old skool baby
old skool baby
How big is the fuel tank? I presume it's a 35 litre tank, so approx 8 gallons?
And how much in litres do you approx have left when the fuel gauge starts to go into the red?
Golf Mk1 Gti Campaign 1.9 with 155 BHP
Mark.
Mark.
According to Haynes manual the early models had a 10 gallon 50litre tank and the later models 9.5 gallon 45 litre tank???wierdmcleeve said
On this topic about fuel, I've just acquired my Mk1 Gti 8v and I was wondering….
…The Cabriolet fuel tank holds 55 litres (12 galls) and is bolted directly to the underside of the body, as opposed to the tin top (45 litres and strapped as on). They are NOT interchangeable.
The Cabby is over 100 kg heavier than the tin top…..
