FPR failure
(In Topic #119418)
FPR failure
I have recently purchased a 16V 1.8 KR *edit* running Digifant II and Digifant fuel pump *edit* that has an adjustable FPR on it. I is an aftermarket Autotecnica Monza with guage - and in my opinion is probably a bit cheap and nasty - but I don't know much better.
The issue I have is that I have noticed that the gauge on the FPR will show me that when the car primes, and when the car is running that I have 3BAR pressure. The issue I have however is that when the ignition is off, that pressure leave the rail almost immediately. This is confirmed as the hoses on the intake side of the rail go limp.
I have clamped the return line after the FPR at the same time as the ignition is turned off, and this leads to pressure remaining in the gauge on the FPR.
My questions are;
- is this gauge on the fpr going to show me the fuel pressure accurately when the car is off
- Digi II should run a 3BAR regulator, where do you buy FPR's in the UK and do you suggest adjustable over a standard one
- Who has a recommendation on a replacement FPR?
I have also got a fluctuation in idle, that as much as I think is the ISV, want to have the fuel issue resolved prior so I can discount that as a contributing factor.
Thanks in advance - Michael.
'76 16V DIGI
But loosing pressure after switching off would suggest a faulty non return valve on the pump, or dodgy accumulator?
rossirvine said
If your running a standard pump, and K-jet injection system there should be no reason for an aftermarket regulator as the metering head has one built in.
It looks like Australian spec with a 16V engine running electronic fuel injection, though.
Love the steelies ross! I run some similar.
'76 16V DIGI
Steelies are the way forward! mine are g60 15" wheels - yours look like mk1 gti steelies? had some on my old one
Thanks anyway, hopefully some DIGI head will spot this and help me out. I may have to go to golfmk2.org.uk for an answer?
'76 16V DIGI
3bar is higher than what digi2 runs, they use 2.5bar as std. extra pressure may have been dialed in for the 16v swap though. does the pressure change with revs? the factory FPR should have a vaccum lead on it which changes fuel pressure depending on engine speed/load. without this i doubt its going to run right.
Personally I'd start by fitting a proper digi2 fpr on there and see where that gets you, assuming one will fit as I assume its some kind of aftermarket fuel rail?
what exactly is the issue you are having though, you just mention pressure loss when off? does the car not run properly?
I am experiencing hard to start so was thinking that this may be an issue. The other problem I have is that the car starves at around 5000 RPM, so it was playing on my mind that there was an issue with the FPR.
Your suggestion will be taken up and I will get myself an OEM FPR, now it is just a matter of determining if it should be 2.5 or 3 as you suggest. The current one has the vacuum line like suggested and it increases by .5 BAR when the throttle is open.
I also changed the idle control screw o-ring today that helped lower the idle RPM from 1500 to about 1100/1200 rpm. When the christmas break is over I will get a new blue coolant and o2 sensor so I know that they are in good order.
Appreciate the assistance.
'76 16V DIGI
So now I need to decide on a replacement fpr, adjustable or not…
'76 16V DIGI
