Found the petrol leak, but where actually is it? *photo*
(In Topic #93429)
Well those pipes are soaked in petrol, so:
1. Where could it be coming from?
2. Easy fix/time required?
3. Parts needed (if any)?
Also sometimes the engine starts fine sometimes it needs to turn over, stop and then it will start first time, related?
Cheers guys
1983 1100 C
1983 1100 C
And is it standard part that I can get at any parts shop or do I need to go to German and Swedish?
Edit: Which ones do I need? :
18600 VAC HOSE General Use 2.00 Add
18602 FUEL HOSE 5mm General Use 2.00 Add
18603 BRAIDED FUEL HOSE 5mm General Use 5.00 Add
18604 FUEL/EXP.TANK HOSE 7mm General Use 3.00 Add
18606 FUEL HOSE 9mm General Use 4.70 Add
18610 JUBILEE CLIP-FUEL HOSE General Use 5mm Fuel Hose 0.50 Add
18611 JUBILEE CLIP-FUEL HOSE General Use 7mm Fuel Hose
Im not quite sure where they go :dontknow: Ideas?
here are the other ends….
I should be able to fix it today then
5mm Braided or 7mm fuel/exp.tank hose?
Had a measure and the metal pipe to the front of the car seems to be 7mm :dontknow:
And I changed it myself, in the wind and rain, and, SHE LIVES!!!!
AHahahaha
I feel so happy.
Not the first time I've worked on a car (replaced Volvo 850 Estates Damper mount).
But she lives and she seems much smoother!
However how fast should it idle? Its about 500/600 RPM and seems very close to stalling, any way of getting that up to say 800?
Cheers for your help lads
