Floor pan getting VERY hot from Exhaust
(In Topic #74575)
Life Member
Check your heat shields still intact!
LOL, maybe you need to do a spacewalk and check the foam tiles.
Buzz.
1980 1600 GTI, daily driver.
I'm pretty positive I don't have one. Would a "driver" have had one fitted as standard or was it just the Gti's?
My Build Thread
there's a heat shield by the fuel tank, rubber gear linkage boot, gear linkage support bracket/mount thingy and the obvious at the front.. just seems the rest of the area is a bit exposed :dontknow:
good luck chap,
paul
costs a bomb in houses!!!!! so you should think yourself lucky.
andunp said
just timk of it as under floor heatin!!!!!!
think the exhaust mounts are knackered as it's sitting a little to one side
1272 driver with a magic tree!!
lowmk1 said
ps. sorry for thread hijack :mrgreen:
if the exhaust is rattling against the heatshield I suspect it's not in the right position (exhaust and/or heatshield).. have you tried bending the shield away?
yep exhaust it tight as, doesnt move about alot and is std(i think) where it meats the heat sheild.
Can i just rip it off and cover the rubber with some sort of heatcover thingamajig
Life Member
