Fitting new fuel lines
(In Topic #75037)
I've seen how tight they are at the front of the vehicle, and having recently done the brake lines on mine and struggled with these, I dred to think how difficult it would be with fuel lines that don't flex as easily in a simelar sized gap!!
Mike.
1983 White cabriolet GTi
This is a job I plan to do after my brakelines. I got a complete set off Rich (Crazyquiff), one original VW one and one he has had remade from an original.
I think its one of those things where it might be worth trying to scrounge the use of a proper ramp as part of the problem is getting access under the car.
Chris
Been there…dun that….
http://www.vwgolfmk1.org.uk/modules.php?name=News&file=article&sid=7&mode=thread&order=1&thold=0
Mk1 GTI
B5 Passat Estate 5 SPeed
Bosch Lawnraker 32
Bosch Lawnraker 32
Automec pipes (fuel & Brake) are delivered with end fittings already swaged on and in coils of about 1 Ft (30 mm if yer not Christian) dia.
http://www.automec.co.uk/
See if Crazy :
http://www.golfmk1.co.uk/
still has the steel pipes if you prefer those…..note my comments about "work-hardening" the copper pipes if you bend them too many times.
Use your old pipes as patterns when bending up the Automec pipes.
Mk1 GTI
Bosch Lawnraker 32
Bosch Lawnraker 32
Have a free tip from me though, if you're going to do them, then take your time bending them acurately, and also make notes of what line goes where on the rear compensating valve. I didn't, and had to look at a friends car to get it right! Also rear brake lines from the rear wheel to the flexi hose on the rear beam are nigh on impossible without removing the rear beam. Also take oppotunity to renew master cylinder and brake light switch as well, improvement to the braking system is enormous with a new master cylinder.
Mike.
