Exhausts
(In Topic #76867)
Exhausts
Hi there, i have a 1100 golf and a am wondering if a mk1 polo exhaust will fit. Cheers phil
Golf c mk1 1100, Needs more power
Doubtful, as the floorpan will be a different shape. You might be able to adapt some sections to fit, but it would definitely be easier to source an exhaust system for a Golf (or even a Jetta).
Ckeers, Do you know then if a golf gti exhausts will fit, Cheers phil
exhaust
you will not be able to fit a gti exhaust to a 1.1 lump…..
i have a 1.1 exhaust complete if you are in need of one
midweekbeatle@gmail.com
full resto on a 80' mk1
abandoned all parts for sale
99' passat 1.9 TDI
99' passat 1.9 TDI
Not entirely true, I have a mk3 Polo engine in my MK1. I'm using the GTi system, Polo downpipe and a 3' bit of pipe in between. I imagine the 1.1 has a thinner system, whereas the Polo is the same size as the GTi.
exhaust
99' passat 1.9 TDI
99' passat 1.9 TDI
You can fit any exhaust to any engine, just depends how much you want to do it.
Hi there, Does anyone know if a gti down pipe will fit a 1100 manifold, because all the performance exhauts i can find is for a gti, or does any one where i can get one for a 1100 from. Cheers phil
No hope of it fitting - GTI (and other big-block engines') down-pipes run behind the engine, whereas small-block ones go down the front and under the sump.
Not sure what performance exhausts are available for the 1.1 - Steve Matthews should know - PM him if he doesn't spot this thread…
