EXHAUST MANIFOLD
(In Topic #73473)
EXHAUST MANIFOLD
This is the worst job i have done on the car , took 3 hours to remove it all so i want to put it back once only this time . If you can help please drop a reply cheers Chudd….
1983 mars red 1800GTi on ATS cups
G60'd, schrick cam, chipped, 70mm pulley, pace charge cooler, rolling road 182bhp 250Nm of torque, 14.50 quarter mile.
I snapped one when I was changing my 1272cc for a Polo GT motor. The reason they snap is that the studs are not of the same metal as the cylinder heads (light alloy) so they craze in and bond themselves into the head. Same as annoying Saxo brake pins for anyone who has done them before…
Anyway, on mine, one the manifold was out of the way there was a small amount of stud sticking out of the head. I hammered an old socket on and turned it out with a breaker bar.
If it shears flush with the head you need to drill it out and send a helicoil down the hole. Alternatively you can get stud extracters specifically for getting snapped studs out - these are available from Machine Mart for not a great deal of money.
Basically you drill a small polit hole in the stud and turn one of these thigns in - they are like self tappers with a reverse thread and you turn them in the "loosen" direction. Theroy goes that when the are in as far as they can be, they will bite and the turning force you continue to apply is in the right dirrection to now loosen the threads the stud is bonded into.
