exhaust manifold to downpipe bolts
having removed and refitted exhaust pipe it has been ok for a while but now the nuts have worked loose and some have dropped off . i did tighten the nuts so why has this happened ? would locktight stop this happening again or would the heat just melt it ? what should i do, or should i just tighten them again ? cheers strength of a teddybear jim. :oops:
Mk1 2l TSR G60.  .getting. There twice as fast
u need to fit a copper/brass lock nuts
thread lock will just burn off
refitted the bolts this time used the recomended vw torque setting. hope this works. driving along awaiting clink, clink thud noise .
Use new NUTS ETC from your local VW dealer [cheap as well]
Part numbers are
 Exhaust Gasket 4 pieces : 028 129 589
Studs x8 for the cylinder head to manifold: 044 411 5
Nuts brass x8 for above studs : 900 850 01
Studs x6 10mm for down pipe to manifold: 044 520 3
Nuts x6 for above studs for down pipe : 102 090 05
You will not have the same problem again
Cheers…….
I used stainless steel on mine with coppaslip..I used two nuts on each stud to:
  1. Lockem
  2. keep the otherwised exposed thread on the studs from rotting away and thus make 'em v difficult to get them off.
Brass nuts would be also be ok (even preferrable) but I would use long nuts that covers the exposed thread as above.
I also used coppaslip on the gasket faces
Mk1 GTI
B5 Passat Estate 5 SPeed
Riley 1071"S" Elf Mk2  (Bl**dy Hooligan machine!)
Bosch Lawnraker 32
thankyou for your advice, and cheers chudd for coming up with relevent part numbers very handy. i think i will change for new as you can still get vw parts  for peace of mind.
