exhaust help
(In Topic #98730)
exhaust help
how does the exhaust go together at the downpipe to center pipe normally as mine keeps coming loose and blowing anyone
should just slip on and clamp up. make sure you have the right size clamp and stick some exhaust paste on it before you connect it up. i find that it's better to undo the rear exhaust too before clamping the whole thing back together.
yea thanks keep trying but still comes loose
Are the pipes different sizes then? There's nothing complicated, it simply clamps together.
dont really know its a new centre bit all standard apart from backbox
take it apart and start again using exhaust paste and making sure you have the correct size clamps. they can differ by as little as .5mm and upwards. if you have a 52mm clamp on a 50mm pipe, it won't help.
yea thanks alot mate think might need a new one as guy who fitted it has cut it too short i think so kwik fit say
