Dodgy fuel gauge... Showing almost full all the time!?!
(In Topic #78063)
Cheers!
Wez
1966 - Split Screen Bus
1980 - Series 1 GTI 1.6
2000 - MK4 GTI Turbo
Id give that a try first mate
Cheers!
Wez
as above, disconnect the fuel pipes (you may want to clamp them incase of spillage) and twist the sender to remove. You may need to clean the contacts, though sitting in fuel, they should be pretty clean!
Check your earth on the instrument cluster too as if this is dodgy it can cause all sorts of instrument problems.
My Build Thread
Wez
Does this look pretty normal to you guys? I wasnt sure if the blue cable was sposed to be there?
Thanks again, i hope it continues to work!
Wez
