Diffrence Between 1.1 and Gti Fuel Tanks.
(In Topic #106088)
Can someone outline what the basic diffrence is between the two petrol tanks? Secondally can a 1.1 tank be used with a Gti puel pump or would it not fit/possible?
Regards
Jas
I think (not sure) you can use a cabby lift pump, which will fit the same hole as your fuel gauge sender is already in, and this will save you needing to swap the fuel tank over. You'll still need the GTI pump, to 'boost' the pressure of the fuel.
