Desperate for help. Mk1 MOT failure!!
(In Topic #77776)
There's a few little things that are easily rectified and a few bits of welding that need doing.
But my main concern is "rear axle fouling the fuel tank, suspension has inadequate clearance with the chassis"
As the car was originally a carb engine converted to a GTi engine we've come to the conclusion that either a new fuel tank has been fitted incorrectly or the rear axle isn't right.
He has said that the suspension seems too short, but when all the weight was put on the axle the problem was still there so it can't be the suspension.
So does anyone know whether a Scirocco mk1 has a different fuel tank being either injection or carb??? Or is the axle different??
Hopefully a new rear beam should sort it!!!
Any help appreciated!!
or is anyone breakinga mk1 Golf and has either a fuel tank or axle???
On mine the tank actually touches the rear beam! This as advised by the MOT is a major safety problem.
The car has apparently been lowered and the mOT tester saidthe shocks are the wrong height. but surely the shock height wouldn't affect the fuel tank touching the rear beam??
My Build Thread
Racing is life . Anything before or after is just waiting - Steve McQueen
