cis injector interchange and flow rates
(In Topic #99909)
Mechanical injection is different to electronic, in that you don't use "high flow" injectors to allow more fuel to flow. Its about reducing or controlling the control pressure and lever/air flap position, ie with mods done on the WUR and basic mixture setting. The "map" of fuel flow vs airflow is set by the shape of the cone, and is slightly alterable with control pressure changes, eg using a 16V WUR which can lean out at low throttle and richen at high throttle.
