Car wont start after changing fuel tank, please help
(In Topic #105215)
What actually sucks up the fuel, isit a vacuum or pump? If i have pipes off of the sender unit should fuel squirt out?
Have tried it with swapping the fuel lines around incase the return was on.
Any help would be much appreciated.
Dom
What is involved in getting fuel from the tank to the engine?? Vacuum/ pump, just so i can illiminate different things.
Remove the pipes that go to tht pump and check you are getting an healthy suck/blow when the engine cranks over.
Have you got an Haynes manual?
You can also disconnect petrol hose-in from pump and blow down it. You should hear air bubbling in pertol tank. Clears line
Fit a see through petrol filter in this hose as well. It filters crap and you can see petrol flow.
In practice, I'd be tempted to prime it, by removing a fuel line close to the fuel pump and sucking on it until I got a mouthful of unleaded. (Petrol actually doesn't taste that bad and is somewhat underrated).
that's how it starts….. next you'll be on the aftershave
paul_c said
In theory, you shouldn't need to "prime" the fuel system, ie the pump should be strong enough to suck the air through and eventually suck fuel. Otherwise, you'd need to visit a garage after every time you'd run out of fuel….
dont do it with diesel though. that stuff is horrible. more like special brew than a nice crisp pint
may i suggest a shell vpower 2008 sir. a truelly excellent vintage.
and would you care for a cigar with that sir.
Have fuel lines on correct way etc to start with. Have managed to suck up fuel through line, but when connected back up you can just see it seep back down through the filter. It just isnt sucking up enough fuel. Tried a new fuel pump, no luck, old one is actually sucking, because if you push it in your hand it created suction, but when on car it doesnt create much suction at all. Feels like its just to weak.
Basically we came to the conclusion that the fuel lines have a minor blockage, or tank had some crud in it. How much resistance should there be as i blow down the line. I can hear the fuel bubbling in tank, but there is a bit of resistance (enough to make cheeks puff out).
We thought of sticking an inline facet fuel pump on it and seeing how that changed things.
Wotcha think guys?
The Mec pump worked before. I would Drain the tanks and Make sure all connections are tight and on correctly. Have a blow ( compressor) down the pipes you suspect being faulty…… then plumb them all again…
or you could try taking a jerry can of petrol and a hose from that to the pump and making sure it runs ( then the pump is deafo alright)
good luck.
get the bigger hammer. it always makes things better…..
Highland Regional host
turn engine over. does it pull fuel though pipe.
if the answer is no the pump is karput
if the answer is yes then your lines are karput.
happy sailing
