buzzing from fuel pump
(In Topic #74471)
1272 driver with a magic tree!!
My Build Thread
mk1 silver campaign totally standard lowered on coilovers magic tree vanilla
Just had a full outer body restore
My Build Thread
AL_Mk1 said
I can really hear my new one from inside, but that might be due to the fact that I have no sound deadening, carpets, or seat in the back to muffle the noise!
Ditto! got a new one and can hear it quiet easily from inside, mines also stripped out..
Type17 said
to see that it is mounted…
Are Cable ties OK…
The output banjo on mine was touching the shell and it caused a teeth tingling vibration
My Build Thread
Type17 said
If it's not this, then it's just getting old, so get saving…
erm why is this an expensive job???
lowmk1 said
erm why is this an expensive job???![]()
Fiddling the position of the fuel pump is free, but if you need a new one, because it's not touching the body (it's just knackered), they aren't cheap (close to ?100, I remember)
Campaign Mk 1 Black
16v Mk2 Red (decsd )
russt said
Excuse me but I'm absolutely sure they're supposed to buzz. Shoot me down in flames if I'm wrong!!
They've spent loads of money keeping these pumps quiet, by using rubber mountings, etc, to reduce what car designers call NVH (Noise, Vibration, Harshness). While the pumps might buzz a bit, it is the intention to cover it up as much as possible, and if it is audible inside the car, it's because the pump is buzzing more loudly than when it was made, ie: it's getting old, and worn.
I've just changed the fuel pump on my Audi 80 (same pump as a Mk1, but inside the tank). The old one was audible all through the car, but the new one cannot be heard at all, unless you put you head down by the sill, just in front of the the rear wheel.
mark
git said
i think i can hear mine when i turn the key in the ignition as it pressures up the system and when i have the drivers window open. not so easy to hear driving with the windows up! it can be more described as a hum than a buzz. it's done that for the last five years?
mark
Sounds fine - if you can't hear it while driving, it's fairly quiet. Also, they go on for ages while making the buzzing noise.
I knew my Audi one was going, because when I first got the car (2003) you couldn't hear it, unless the rear seats were folded down, but towards the end (May this year), I could hear it as loudly as that when the seats were up. When I took it out of the tank, the area around it was covered in silver metal filings from the parts inside the pump wearing out…
