buzz noise from underneath rear!
(In Topic #105898)
Cheers Trigger
Life Member
1986 Cabriolet (long resto!)
Follow us on:
Follow us on:
Thanks for letting me know
Life Member
trigger said
It makes that buzz sound when the engine is turned off as well, does this mean it needs replacing?
When you first put your key in and turn it to ignition on, but not cranking it should buzz twice "prime" and then not run again until the engine is running.
If that makes sense?
Follow us on:
Follow us on:
Life Member
trigger said
its been turned off for about 40 minutes and its still making that buzz!
That doesn't sound good if I'm being honest, It shouldn't be able to run without the key in because it's on a relay which if the ignition is off cuts the fuel, just incase of an accident.
Have you got a haynes manual, if so, I'd pull the fuel pump relay out of the fuse box and see what happens.
What car have you got btw mate, year, engine, tin top or cabrio etc?
Follow us on:
Follow us on:
1984 white s2 golf gti , 2017 Golf R
Life Member
trigger said
its a 1.8 golf gti tint top on a Y reg, i will check the manual now as its doing my head in and i dont want to do any daqmage to it. cheers.
Mines got a later fuse box in it (out of a 92') and I think it's different to yours cause it's got a third row for leccy windows and power hood or something so I can't help you with it's spefiic location!
Hope you get it sorted though, keep us updated.
Fuel pump relays are a pain, I have a couple laying about that I can send over to you if need be though. FOC
Follow us on:
Follow us on:
woky said
mine makes a buzzing noise, av done for 5 years now
A buzz or a hum? I suppose it depends on how loud, etc. Maybe I'm just spoiled because I've always used either Bosch or Mercedes fuel pumps (yes the Merc fuel pump fits on a VW, with a little fettling).
Life Member
Mine properly buzzes as in you can feel it kinda vibrate the car, but it runs fine.
I thought all the GTi fuel pumps were Bosch anyways? (I've never had to emvoe mine *touching wood*)
Follow us on:
Follow us on:
There's a good chance someone's bodged the cradle it sits in. There's rubber mounts to stop it making noise (by vibrating the local bodywork too) and transmitting to vibration to the rest of the car.
Life Member
Ah alright, didn't even think of that, i'll have a look at it when jack frost strops trying to freeze my fingers off, fed up of messing with the car today
Follow us on:
Follow us on:
Thanks for the help everyone just hope it will be ok, whats the damage to replace the electric fuel pump if its knackered?
Life Member
The MFA always mess up when you battery dies, mine says all sorts of rubbish, it was 9:59am for a good week before I dissconnected my battery / re-connected the battery
Follow us on:
Follow us on:
Will update saturday with hopefully some good news!
Life Member
trigger said
not checked the relay, i will have a look saturday. The battery is still running low though, would this effect the pump?
The pump constantly running has probably just drained the battery, just disconnect the battery till you have a chance to look at it.
NB: the pump runs contantly with the engine so I very much doubt you've damaged it
Follow us on:
Follow us on:
hello!
