Bad fuel pressure?
(In Topic #76894)
Bad fuel pressure?
Firstly, does anyone have any suggestions on what this problem might be, bearing in mind I've checked breather pipes, timing, inlet manifold, adjusting the mixture. Could the fuel accumaltor be something to check?
Secondly, if the fuel pressure is worth checking, does anyone know where i can get the tool cheap or know the whereabouts of one that i can borrow/hire??
mine did this a while age and it was unmetered air getting into the engine causing it to be tuned up running lean so it fired up to 1300 -1400 rpm and then gradually dropped and dropped till it stalled
nick said
I followed a pipe out of the tank which ran directly into what I think is the fuel pump. It is situated underneath just in front of the back wheel on the drivers side, I took this pipe off and found no filter at all…could this mean i was looking at the wrong thing?? It also had a positive and earth connection on it…
nope your right, that'll be the pump
it does sound like not enough fuel or unmetered air
really easy to get to.. it the 7mm bolt on the very back of the throttle body, it's held in with a rubber washer
not sure if it's a good idea but might be worth wrapping it in tape and seeing if it makes any running difference, that way you haven't moved it if that's not the problem :dontknow: might work might not
did have one constructive chat in the pub though…someone suggested i look at the WUR. i've done a check with my meter on this before but it produced readings specified in the haynes, so does that mean it's all working ok? also, i might need to check the supply and return lines for the fuel, does anyone have any suggestions on how to do this (safely)?
did the checks as listed in the haynes manual. couldn't get it to start with the tap closed, so did a cold test with wiring to WUR and auxiliary air valve removed. the reading was well under..i'm assuming this points to a faulty WUR? anyone got advice on where i go from here?
I can look up in my haynes if you need to know the right pressure.
greets yal
anyone got advice on whether i should buy 2nd hand or new injectors?? got a quote for new ones of ?30 plus VAT each one..?
a new problem has now come up…there's no fuel getting to the injectors now!! fuel is getting as far as the outlet end of filter but that's as far as it goes. could i have caused some sort of air block by checking the return line??? can't work out why the fuel isn't reaching the injectors… :dontknow:
ps also checked the power going to the fuel pump, initailly was full 12v and then drops to nothing, this shouldn't happen should it?
