attatching exhaust
(In Topic #99979)
attatching exhaust
first question is, do i need to put any exhaust sealent between the 2 halves before they go together,
second question is, is there some sort of tooling to prize the clips open so tha they will hold the 2 flanges together? because they are a bit bloody stiff to put on by hand
thanks in advance
Clever paul posted the above ………You may need a new gasket .
granted it wont be the correct clamp for it, but surely if i tighten it up enough it should do the joc shouldnt it? of any other ideas you people have??
thanks in advance!
Here's a pic of one when i changed mine, original was falling apart a little, had an hole, but whilst i did this thought i'd change the exhaust manifold gaskets, bolts and studs to stop the rust happening again on the studs, whilst i was at it
Pete
thanks guys
