Alternative Warm up Regs?
(In Topic #77032)
Chris
Regards Volkswarren
& T Reg S1 GTi Project, Still Looking for Series 1 GTi's or a 16S Oettinger to restore (Complete Cars only) or an A reg Lhasa Green or White Gti to restore, also consider Black, Red or Blue, Project Wanted anything considered WHY
Website Manager
Both the WURs you mentioned can be adjusted to correct pressures for the DX engine with a little care and practice.
The Audi (I think the 16V) one has a vacuum take off pipe which acts as a fuel enrichment device. It works by the fact that when you stick your foot down the plenum chamber experiences -ve pressure, hence the vacuum to the WUR drops, which causes the control pressure in the WUR to reduce which allows the metering head plunger to move a greater distance for the amount of air that the engine is drawing, hence a richer mixture. The vacuum soon returns to the correct level and therefore so does the fuel/air ratio controlled by the WUR control pressure.
Cheers,
Ade
