air flow meter problems car wont start HELP!!!!!
(In Topic #86242)
basically i got a mk1 golf with a mk2 1989 k-jet 16v lump in it,
all was working fine untill the other day when after a good bit of throttle it ran lumpy, stalled. it then restarted temporrally then died for good
there is a spark and fuel getting in to the injector head from the filter but then none will come out of the 4 outlets any tips? or just a new air flow meter. is this the problem?
ed
still no joy
no fuel is coming out of the injector ports????? help
i need my car on the road as its my job (pizza boy) and obviously my daily drive
Did the same as you and swapped to a diferent metering head, but no difference.
Plenty of fuel in the filter, and when I loosened the screws on top of the metering head that attach the injector pipes to, there was fuel there to!
I also swapped the injectors and no fuel there -
Is it possible to get a blockage in the pipes?
Only part I havent renewed / replaced is the accumulator - could I be getting insufficent fuel pressure?
Help us please 8O
my car randomly started today and all was working well about 3 miles later tryied to park it didnt idle stalled itself and wouldnt start again.-TOWED HOME some one PLEASE help
3 bar produced by accumulator ? i read some were else on the forum 17psi is needed ? but this doesnt equal 3bar
( 44psi = 3bar ) - I got a pressure problem also been trying to find out !
sled-bmx, theres a injector test some were on here or link to it, shows you how to test your injectors ….
