Accessing inside of fuel tank
(In Topic #85548)
Any ideas?
Thanks in advance
Mk1 GTi White Cab '86
Mk4 TDi
Mk4 TDi
I don't see why you can't release the hoses, they're just hose clips and then they pull off. Maybe you need to carefully cut the hose clips if they're perished, and replace with new ones. There should be a little slack in them to allow their removal and replacement.
Not sure what you mean by locking ring? the sender is a bayonet fitting and should knock/twist off :dontknow:
Early-1800 said
supply and return on a GTI??? Carbs have them but the GTI should have the connections direct to the tank not via the sender unit?
Quite right. I assumed it was a non-GTI, or a later cabby.
Mk4 TDi
Mk4 TDi
Not sure what date either the change was :dontknow:
I also think the later ones had a lift pump in the tank like the MK11 GTis :dontknow: :dontknow:
I'll have a go with the a hammer and chisel later. The photo isn't focussed but the collars are loose and the tubes are stuck fast.
Mk4 TDi
Mk4 TDi
..USE a WOOD DRIFT on all three (avoid any possibility of sparks and explosion…)
late cabby lift pump and filter…BE CAREFULL WITH THE 'O' RING - best to replace with a new one and use fuel to lubricate it when putting it all back together….
..more pics ..here..
Cheers Prowler. That clears things up and helps a lot.
Mk4 TDi
Mk4 TDi
Mk4 TDi
Mk4 TDi
dannyboyblue said
Any ideas where I can get the O ring from? GSF only provide the ring as a seal not a filter (part no. 93699) (thats what it looks like in the picture on your website). Vagcat doesn't list a part no and my local stealer hasn't got a clue what it is.
Easily available from any VW Dealer. Go back to the dealership and ask to speak to someone in parts who knows what they're doing!
Haven't found an employee there yet who does know what they're doing!
Mk4 TDi
Mk4 TDi
Name & shame?
Have ordered it from Motorline VW for collection on Friday for the princely sum of ?1.18.
Mk4 TDi
Mk4 TDi
dannyboyblue said
Sir, you've done yourself proud again! Thanks
what, no bartering?
Mk4 TDi
Mk4 TDi
Josh
I'm also tring to access the fuel tank (84 cab GL), but the top of the sender unit in my case is a white plasic affair that doesn't really look like it's up to much shufty-ing witha chisel. However, it's stuck fast! I've taken off the fuel send and return pipes and the wiring, so does anyone have any clever ideas?
The old haynes book doesnt really give much of a hint, just to use two crossed screwdrivers. I'm no mechanic like, but erm…it doesnt work?!
Cheers!
1984 Mk1 GL Cabriolet, black.
