A bright idea to stop rust bits destroying fuel pumps?
(In Topic #88637)
I have a (new-to-me) '83 GTI 1.8, which was a non-runner. I established the fuel pump was not working, just a dull 'thunk' when powered up. 12V was there, so tried an old pump off my old Audi 80 and the car ran fine - for about 30 minutes. Then one time I turned the car off, when restarting the pump didn't run, just clicked as the original pump had done. I dismantled this pump later and found quite a few bits of rust within that could have jammed the pump I believe.
So, ordered a brand new pump from GSF, and to be prudent, cleaned the tank very thoroughly in situ to rid it of the rust bits from the old filler neck (new one fitted before my ownership), by using a telescopic magnet, air-powered grit blasting suction pick-up, and hoover nozzle (when dry). The tank was totally clean and in good condition as far as I could see - took me about 4 hours…
Fitted new pump, re-fuelled, started fine, and ran for about 10 minutes (fine under hard throttle too) before the pump packed up and 'stalled', this time blowing the fuel pump relay with it. Now I'm pretty sure another unseen bit of rust has jammed this new pump, and I don't fancy buying a new tank just to ensure the tank is clear of crap, or keep buying new pumps which last 10 minutes…
The tank has the black baffle box in it, together with a good condition cylindrical filter within, albeit with no 'bottom' to the filter, but this doesn't appear to be doing any good, SO, my idea is to route the standard 90 degree inlet pipe from tank to fuel pump via a simple in-line filter to protect the pump. This part is at low pressure so should be ok. My question is; Will such a filter. like the inline engine bay filters on carb'd Golfs allow a sufficient flow rate for the injection system, given that delivery is far greater than consumption?
And are there any other pertinant issues I'm missing?
Please help, as this is starting to get me down, and is also getting expensive!!
An update - this morning, after much overnight thought, I decided to try to lash up the very same arrangement as Early-1800 had done, purely coincidentally.
Having looked at where I might mount it, not so low as to be under threat of damage from hanging too low, the only in-line filter I could think of was the little one that carb'd VW engines use, but was concerned about flow rate given that the bore of the supply and return spouts are 5mm, compared with 10mm for the original GTI pipe, which is a lot less. However, I filled a funnel with petrol and poured it through the little clear paper filter and the flow rate was surprisingly high - the paper filter didn't 'back-up' with fuel at all, so I thought it might work.
I cleaned the tank again, and this time poured 5 gallons of fuel from the tank, through a paper filter from one jerry can to another, about 4 times, to make sure the fuel was clean. This alone removed a lot of rubbish, which had abviously come out of the tank with the petrol. This may well have been half of my problem. I then made up a loop of petrol hose, with reducer sections, to fit the in-line filter between tank and new pump (which had just turned up by courier), tie-wrapped it up out of the way of the moving rear axle, and decided that it had better be tried… Also had to replace the 15 amp fuse as the stalling of the 'old' pump had blown the fuse.
Car started fine, the little filter is passing loads of fuel, and ran the car under hard throttle up the lane in 2nd and 3rd to be sure of sufficient delivery. I must say I'm a little surprised, but the car performs just as it should, good power, good tickover, good hot and cold starting, and only a very few bits in the in-line filter thus far. Can anyone see any problems of potential damage I might be doing using this method?
Good advice about the Metro filter though. My concern was I'd struggle in an auto factors as they'd just want a car model to raise a part number from, rather than be able to dig a load of filters out and let me see what might work best. So I'll keep that gem of advice just in case the little filter I have fitted does cause some problems in due course. But at the moment, all seems well.
Thanks again for the good help - there's obviously a lot of experience on the site! I'll keep you posted if there are further problems. Cheers.
Good thing about that filter is you can see any crap it catches and be certain when the tank is clean…
Good job!
Alternatively can anyone suggest a suitable filter that doesn't cost $$$?
fuel filler neck
myspace.com/ailsa_rockart
M
I checked inside the tank a couple of weeks ago and it looked clean. Out of interest where did you stick the magnet so you can easily get it out again?
Alos I noticed some very light whitish corrosion/oxidation on the first couple of inches inside the filler neck (got my hand all around the outside of the neck, totally sound) - could this be a problem?
Cheers all
magnets
If not might explain the oxidation ?
I put some magnets in a cloth bag tied with string (not the plastic type)
and put it in the tank through the fuel gauge sender unit located under the seat. Just unscrews leave some of the string outside of the guage so you can pull the magnet out to clean. I did it three or four times and it came up really clean I couldn't even see the bottom of the tank when I started.
There was a thread about it last year but can't remeber who it was
but it helped me no end but I'm still finding problems along the fuel systems but does look like it's coming to an end
