4 Branch Manifold
(In Topic #80843)
4 Branch Manifold
i am after buying a 4 branch manifold for the citi, problem is i am confuised as to what to look for as they are all different plus which one i should buy.
Also would rubber gaiter on the steering rack be a problem as regards to being burnt from the exhaust when it is fitted
Best wishes and thank you
I only had 2 issues with it .
one was getting all the exhaust pipes on to the studs for the cylinders .
all the branches are seperate on the supersprint and could have done with having a mounting plate rather than 4 seperate pipes .
if you can see what i mean in the picture .
the second issue was the gaitor on the steering colom . i assume that the supersprint was designed on a left hand drive car being italian n all so there was a slight problem here . luckily loosening the engine mouts gave enough movement to the n/s to give a 5mm gap between the two so i could smother the 4 branch in lagging .
i then found some sheet lagging and wrapped the gaitor in this .
all is ok now .
my engine is a 1.3 with a 1.6 block, i think your manifold is for gti? am i correct in thinking so, sorry to sound dumb bud but i haven't a clue, so which manifold would i need for mine :dontknow:do have a pic please
Best wishes and many thanks bud :wink:
or drop in a 1.6 carb engine,will go straight in,i was going to do this with my citi as its underpowered with the air con turned on,but the miles i do in the citi it wasnt worth all the effort,plus its cheap tax :dance:
Bert
The kiehin carb is brill on mine, plenty of power for a 1.3, i am well happy with it, but like you say, cheap on tax, but i thought putting a 4 branch would make a difference, as i dont like the manifold with the c clips has it sounds as thou it is leaking even thou it is not, but it is slighty rusty and by replacing with a 4 branch and no joint on manifold it would be quieter or am i talking untter rubbish now lol, need guidance on this.Bert said
Hi,i would dump the carb first,the S.A carb is poor so if you want more up and go get a webber for it,the manual choke is already there :wink:
Bert
Is there any other way of quietening the exhaust or is this a common thing on the citi's, as i dont have this problem on the c reg mk2, i really am not bothered about power just a nice quiet exhaust, engine runs true and smooth.
You lucky bugger, i dont have aircon on mine :cry:
best wishes :wink:
1983 MK1 Golf GTi
i always have the last laugh
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
Any part numbers and would you recommend gsf or stealers?
Thanks again
i tried adjusting my engine mounts but to no avail so i just removed it
it is also advised to use exhaust wrap as the manifold kicks out some mega heat :wink:
If u look at a dyno read out the 4 branches tend to widen the power band , and give a slight increse in top end bhp .
Peak power is how much power the engine can possibly make . so for instance a car may have 400 bhp at 6500rpm but make hardly any power before 3000 rpm . this dyno graph would look very flat and then peak right at the end .
I`d rather have a car with 200bhp but produced power from 1500 rpm round to 6500rpm , this graph would show a steady curve all the way up to peak power . This car would be alot more driveable , and this is the kind of power curve improvement you would expect from a good exhaust . to assume putting a 4 branch on will bump bhp from say 100 up to 115 isnt very realistic , it will probably add at most 8hp but spread it through the rev range , improving mid range and add a couple on top .
When i installed mine it was inconjunction with other mods but i know if i hadnt done it at the time id still want one . im sure you all know what i mean .
