4 Branch manifold fitting
(In Topic #89319)
Bought a four branch for the 1.5 block, hear about studs etc snapping.
I am planning on cleaning most of surface rust from studs etc and soak them for at least 2 days whilst still attached to the block with wd40 before i attempt to remove them hopefully not snapping any.
Would this be the safer way?
If one does snap, how is this removed and what else would it entail.
Pete :wink:
Bert
Not planning on rushing it as i know that can cause further problems.
Will buy a little blow torch to apply heat, even if it takes me an hour for each stud, so be it, it will save alot of hassle as i found out from other members.
If by chance any do snap, are they available at dealers fella
Pete :wink:
Pete
What I should have bought was an acetylene one with an automatic spark built in, so you just squeeze the trigger and it lights instantly. One of these is just the job.
HTH
Rich
Another tip is to turn the nut the wrong way initially (ie tighten), to break the seal on it.
Thanks both of you, very much appreciated
Pete :wink:
Used a 12 6 sided socket and turned slighty tightening the nuts, then gently undid them, all came off smooth even thou the whole bolt came out as the nuts were locked tight which helped undoing really, so happy chappy
Ordered some new bolts and nuts from gsf, collect monday and then get fitted.
In mean time need to find a piece of exhaust 45.6mm thick in order to fill the gap between manifold and centre box, hopefully find a piece on a bigger engined car in scrappies tomorrow.
Thanks again all for your experienced advice, it helped loads and gave me a plain sailing day
Pete :wink:
Well happy with results, nice and quiet, thanks again to all that gave me top information and enabling me to complete what i set out to do, big thanks
Pete :wink:
