1300 mk2 engine ??4star/lrp???
(In Topic #77136)
got told that i could put four star in my mk1 golf, got told it would run ok and would do it good rather then harm. is this true??
it has got the mk2 1300 (hk engine code) in it. is it worth me puting 4star in every now and again, and can you mix 4 star with unleaded or optimax?
many thanks
sorry if this is a stupid stupid question
simon
i always have the last laugh
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
much appreciate your advise,
p.s. did you notice it running better on 4star or lrp or not at all?
many thanks
simon
<a href="
I'd imagine mixing LRP, unleaded and optimax would mainly effect the octane rating. Most LRP is 97-98 ron, optimax and other super unleadeds 97-99 ron and standard unleaded 95 ron. Your HK engine will require no more than 95 ron.
1983 1100 C
1983 1100 C
just stick to normal unleaded it is then,
thanks for the replys guys
<a href="
so if i put super unleaded in, i may do somedamage to the head, valves etc? am i right
No, only if you use a petrol with a octane rating lower than is recommended for your engine - higher octane than required should cause no probs. The octane rating relates to efficiency/effectiveness of the burn - the higher the better.
GTI engines e.t.c are normally set up to require high octane fuel (originally 4 star, then LRP/Super unleaded) of at least 98ron. Lower octane petrol can cause 'pinking' and ultimately cause damage unless the timing is adjusted to suit. HK and other small block engines (bar Formel E spec) will not require anymore than 95ron octane (standard unleaded). Using higher octane will not cause any harm and you may notice slightly better economy/performance.
1983 1100 C
1983 1100 C
<a href="
