1300 driver cuts out help needed
(In Topic #77224)
Life Member
"1300 Golf Driver dies, help needed" Call 999! 8O
Sorry for thread hijack!
Cheers,
Drew.
Once a Mk1 fan, always a Mk1 Fan...
Re: 1300 driver cuts out help needed
I may be a dead driver soon if i dont get it fixed and get it out of my mums garage
Life Member
Cheers,
Drew.
I recon this will sort you out..
Basicaly plum straigt from the pump to the carb, not ideal but it shoudld work till you get a new vapour trap.
TT
TT
1983 1100 C
1983 1100 C
dont make them anymore, according to vdubb, they are specialy orderd, at a bargin price of ?80 :evil: unless your lucky enough to go to your nearest carb shop and see if they have one lieing around like i did for 17pounds
i always have the last laugh
<a href="
http://i44.photobucket.com/albums/f27/sim0n_parker/paulforwebsite.jpg<a href="
Our car started cutting out intermittently.. and it started getting worse, ususlay when accelertaing.
I spent about ?300 finding the problem ( garges kept saying it was most likly the ignition! ) a recon carb which did not come with the vapour trap and did not help!
You should be able to get something to do the job from Filter King..
TT
Cars are new to me so thanks for all your comments (TT)
i will have to have a look at my haynes manual as im not quite sure about what every thing is.
have you got deatils for filter king (TT)
The vapor trap is easy to locate.
Take of the air filter housing.
From the fule pump you will see a pipe going to a cylindrical tank on the side of the carb. it has 3 pipes.
1)The one from the fule pump
- The feed to the carb
- the fule return to the petrol tank.
Basical take the pipe from the pump, straight to the inlet on the carb. Take it for a drive and see how it is.
If that fixes it then you need to look at finfing a new Preasure Reg/Vapour trap …
TT
had a look at the fuel filter and think i will change it any way does not look too good.
Keep an eye on the new one over the next week or two. If it starts dirty again then you've got crud in the fuel system, causing poor fuel flow. What condition is the filler in?
1983 1100 C
1983 1100 C
