1.6GTI metering head vs 1.8?
Read somewhere that the 1.6 GTi metering head is better somehow, flows more, is this true?
I may be wrong but am sure that the K-Jet systems on the 1.6 and 1.8 are identical!
I thought that too, its just something i read somewhere once :oops:
You're not wrong, Tim Stiles claims that the 1600 metering head has better fuel flowing in his recent Golf modifying book - not sure why. The metering heads did change during production (early ones do not have the four hex head adjuster things).
1983 1100 C
Ah, you learn somethign new every day! Cheers Mark! :wink:
so.. would a 1800 metering head work fine on a 1600 engine?
was going to use a spare I have which is from an 1800 while I clean up my one but if it's possible it'll cause problems I won't bother  :?
_________________
'82 Black 1600 GTI - Getting Better
Talking of which just won this on ebay Metering head
Hope it's the bargain I'm hoping for! :dontknow:
I'd say you've got yourself a bargain!
you have been busy on ebay recently haven't you  :lol:
_________________
I'm sure that I've seen the metering heads on USA web site for about $200-$300?
Shopping therapy! :lol:
According to Autodata the 1.6 GTI runs lower fuel line pressure than the 1.8 so I'm guessing the 1.6 metering head is calibrated to let relatively "more" fuel through.
Bear in mind though, if you simply increase fuel pressure - all you are going to do is hold the injectors open for longer and thus overfuel the car.
What you need is a rolling road and gas analyser plus someone who has all the various springs to recalibrate K-jet for you.
Out of interest, what engine are you running at the moment and where are your problems/flat spots?  Might be easier to wire up a floor switch under the throttle pedal to switch in the fifth injector at full throttle - all depends on what the car is doing and where it is down on power I suppose though.
My metering head arrived today - brand spanking new!! Bargain! :y:
?14 for a new metering head :clap: Well done on that one Hairyarse, thats one hell of a bargain.
1983 1100 C
I saw those one ebay, the guy had a couple I seem to remember...
bengti said
I saw those one ebay, the guy had a couple I seem to remember…
Yep, think he had three and mine was the second I seen on ebay - the first went for around ?20 I think :dontknow:
Well chuffed - wont be fitting for a while yet but looks spanking!! :wink:
