1.6 GTi Fuel pump test
(In Topic #80667)
Just a quick question - if I connect my fuel pump direct to the car battery, should the pump turn over?
Also, is this a bad idea?
Apologies in advance if these are really dumb questions!!!
Rich
My Build Thread
My Build Thread
Same problem
the car was fine a couple of weeks ago then i let my mate drive it, the ACC pedal got stuck and the car decided to red line the crap out of itsself.
he dropped it into neutral and the we switched teh car off immediately, i hadnt started the car since today.
the battery was flat so i took it back to euro and thay said it was dead, so he replaced it. as it was only acouple of months old. then i went to GSF and got a fuel pump relay for ?17.35.
now ive checked the compressions and number four 4 3 2 1
is at around 100 and the others are fine., but there is no fuel gettin to the engine for some reason
there is spark,
when i turn the car i can hear a strong click from under the car, which is the fuel pump, cant hear a buzz, but then again, not sure if there is enough fuel.
so my question is whats the best solution, does the pump not buzz if there is no fuel.? or is it stuck or sumink/…
help
Birmingham
Rich
j
what other fuel pumps out there are compatible with the mk1 gti 1.6?
and has anyone got a newish one for sale?
thanks
Birmingham
I had the same symptoms as you - fuel pump would click a little, but not turn over, and there's no fuel getting to the engine.
I'll let you know how I get on…
Rich
Guest user
s
when my car was redlining it seized up the fuel pump, which blew the relay and shorted the battery, all bad things come in 3s, so all ahve been changed, now the car is giong for its MOT and then TAZ and then just to be driven,
thank god forthis forum.
ps if anyone needs any bits ive got loads lying around, cheap too. very cheap
Birmingham
