wiring problem
(In Topic #89492)
wiring problem
the problems i have are
my fuel pump is not switching on when i turn on the ignition i have changed the relay the fuel pump works when i bypass the relay.
the other problem i have is i have no spark but i have power at the coil i have changed plugs,leads,rotor arm and the cap but still no joy.
any advice or help will be very welcome :dontknow:
you need to find out why you have no spark first then the pump should work :wink:
try the amp located in the passenger side scuttle that could be faulty gsf sell them i think
