Wiring Loom!!
(In Topic #149049)
Wiring Loom!!
Ive just taken the dash out of my 82 Gti to find a birds nest of wires which someone has chopped about and decided to call a fuse box.
Im going to need to change alot (if not all) of this and aquire a new fuse box and loom.
It has the original CE1 fuse box and ive heard that its best to upgrde to a CE2 fuse box. Am i right in thinking this?
Has anyone got any advice on where i could find this parts (Loom and Fuse box)?
And
If im correct in thinking it best to upgrade?
Thanks in advance,
Dan :-)
2005 A3 TDi 1982 Golf GTi 2007 1 Series
i would try and repair it or get a loom and fuzebox that is the same as what you have then you wont have to run new wiring through the car
id look on the breaking a car section for the parts
As for stripping the car… That's the easy bit. Lol.
Dan :-)
Its reassuring to hear someone say that what I've been confronted with doesn't look badly wrong or dangerous. So thank you :-)
if you do decide to replace/refurbish go CE1 at least, or CE2. CE1 is mk1 golf from 1983 onwards, and pre-90 mk2 golf. CE2 is 90spec mk2 and mk3.
if you have the late dash and large rear lights then go for a mk1 gofl loom complete, direct swap. mk1 cabrio post 83 will do for engien bay and dash, but rear loom has no wash/wipe plus you will need to splice your old rear light plugs on
