Wiring Help (ignition stays on constantly)
(In Topic #94348)
![g60mvr6 in the usergroup ‘Local’ g60mvr6 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
any other ideas fellas?
this will be much appreciated
![chudd in the usergroup ‘Local hero’ chudd in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Has some good wiring diagrams [click on the top link] , it's difficult to give an exact problematic solution unless the wiring loom is standard .
Has the loom been messed with ? Have you had the ignition switch out ? [The bit under the key] These can burn out .
