wiring diagram for clocks in centre console please
(In Topic #143927)
Just wondering if anybody has one to write up the oil pressure, oil temp and battery voltage. the auto electrician seems to think that if he wires up the clocks in the centre console the ones in the mfa won't work. Any ideas?
mk1 silver campaign totally standard lowered on coilovers magic tree vanilla
Just had a full outer body restore
you need to fit a 2 pole pressure sender which replaces one of the oil pressure switches, then either use a t piece so you can fit the vdo oil temp sensor as well as the mfa sensor or remove the mfa sender and just use the vdo.
apart from that its easy they need an ign live & lights on feed from fusebox, and an earth. plus oil temp and pressure wire to senders too obviously
Thanx maaan 8)
Thanks that a great simple wiring diagram for this.
Where is the best place to get one of these?
Spill.
Spill.
an audi in the scrap yard, or ebay
