wiper/indicator stalks?
(In Topic #73638)
The wiper problem sounds like the relay is missing (postion 10 on the relay board, if it's an '83/'84 car, or position 4 on earlier models) - if it's not gone, you need to check it, and check the stalk-switch too.
The issue sounds like it's unrelated to changing the wheel.
re:
try taking all ur fuses out one by one , check them & replace them making sure thaey are all well in…..might be surprised!
As for ur wiper's, take plastic off steering rack & look intoterminal where stalk goes into & u should see 2 little brass terminals, tryputting ur finger on the most obvious one u see as push it forwards to see if it makes a difference. If it does, get hold of a nylon cable tie, cut a piece from it about 2 - 3cm in length & try to insert it between terminal & black clip holding it in place. i super glued it in place & it all works fine now! This is very handy if washer jets are non existent or weak as the black plastic clip keeping it tight seems to melt/wear after a period of time.
