where to get ceramic fuses and relays
(In Topic #87519)
does anyone know where I can get fuses for this? I think they are called ceramic fuses - they are plastic cyclinders with a strip of metal on them
also does anyone know where I can get a set of relays from?
thanks
Matt
You should be able to get new fuses and relays in a motor factors or Halfords, but they will be relatively expensive, as they are only expecting you to buy one or two as spares.
A better bet would be to go to a breakers yard and strip the ones you need out of any pre-'82 VW (doesn't have to be a Golf, or even a GTI [except for the fuel pump relay]). Note that many of the relays from VWs with the later (blade-type) fuses will be fine in your earlier fuseboard.
Do you know which relays you need, and what they look like - you won't get far at the motor factors or breakers if not… (Haynes should have details)
Far too many toys…
…and a big smiley face!!
