What is a TCI-H unit?
(In Topic #123523)
I am currently putting a 2L 16V 9A engine in my golf and I am having a blond moment.
As I am using twin weber carbs I am not using the 9A loom or ECU, I am just using a KR Ignition Control Unit and it's loom. However I seem to have a plug hanging with no where to go.
I know it's called the TCI-H plug but I carn't for the life of me remember what it stands for, or what it does.
Help please
Coil – Distributor – Module
TCI-h = Transistorized coil ignition with Hall sensor
The above shows the TCi-H system for a a 1.6 carb, to give you an idea for your 16v.
I have everything on the Ignition Control Unit loom pluged in except that TCI-H plug. What does it plug into?
Thanks.
For info, all TCI units are the same across pretty much all VW models which have them.
I thought it plugged into a sensor in the engine/dizzy or something not an independant unit.
Thanks everyone for the help.
