Weird annoying temperature gauge problem.
(In Topic #74809)
If I'm running my car (1983 cab GTi) with nothing electric turned on it runs absolutely fine. as soon as I turn something relatively powerful e.g rear heated screen or headlights, if the engine is at operating temperature it will cause the red overheating LED to start flashing, literally at that second. (the guague stays in the same place) Turn them off, it stops instantly.
I'm pretty sure it's a problem with the voltage in some way causing the gauge to think the engine is hotter than it is. The needle on the gauge never moves, always stays in the same place roughly, which on my car is about 3/4 of the way up the guage. (Is that the normal position for it to sit?)
Any ideas???
mike.
1983 White cabriolet GTi
I got a full set of donor dials and rebuilt the lot.
Search space invader on this forum for further gauge chat!
Peter.
1980 1600 GTI, daily driver.
Mine does too, when i turn the lights on and the mfa oil temp jumps 12 degrees :dontknow:tallpete said
My temp gauge used to go up about a quarter of the dial when I switched the headlights on!
Peter.
Anyway the science won't help you solve it, I personaly would start with the battery terminals and make sure they are clean then check the negative one conneted to the body, Not sure how it is connected on a Golf but make sure it free of rust and corrosion. if it is clean it to bare metal wear it fixes. then see how the light fares.
PS My gauge sits just past the red LED, but the owners manuals says between a 1/4 and 3/4 is fine.
just had a look at my car and the earth for the battery goes to the top of the gearbox, there must be an earth strap to the body underneath somewhere, could be a poor connection there.
PS always diconnect the battery before playing with any connections !
Audi A4 1.9TDI - Gone
Look here http://www.vwgolfmk1.o…c&t=4065&start=0&postdays
Rob
