VW GOLF MK 1 Temp & Feul/petrol gauge not working.
(In Topic #106685)
If you need to take the clocks out this thread shows you how to - it's really quite easy once you've done it once.
The clocks themselves are modular, so you can replace each part of it separately - however if you can get hold of a known working set you can do some simple tests to see what may be broken on your clocks.
HTH
Rich
Is there a tie up between the voltage Regulator, the blue wire and another part that could prevent the battery being charged. Or for all intend and purpose can I drive the car without a working fuel gauge and temp gauge?
or until I get hold of a 2nd hand instrument panel!
HTH
Rich
