VDO Oil Temperature gauge
(In Topic #140922)
I am wanting to install the three extra VDO dials to my Golf GTI and I have a 180 degree oil temp sender but a dial that only goes up to 150 degrees.
Will this combination work correctly ?
I believe, form what I've read, that the 150 degree dial is more authentic and that the 180 degree dial is an Audi unit.
The sender is marked 049 919 563B and has VW and Audi symbols on it and says "6-24v 180 degrees" on the side. Will this combination cause problems or false readings?
Please help!
the blue 180degree audi sender is a different rating
if you want both you;'ll probably need to buy a T piece, m10x1 is what you need
Which would be the correct sender?
my abf runs pretty cool as they have a slightly colder stat in than the average engien so i find the vdo temp gauge is basically useless day to day
