Uprated headlight loom but only one side working!!!!
(In Topic #95629)
yeha said
Is there a separate relay for dip and main? Are both lamps connected in the loom or at the relay? A fuse should be before the relay so if both lamps come from the same relay, the fact that one works means the fuse is OK.
There are 2 relays, should there only be one? The left loom conects with original connection and the right is running off relay, i think…. :? . The is a fus before the relay and they are both 10amp.
