Temperature Gauge Reads Maximum??
(In Topic #117109)
Any ideas??????, the engine warms up okay and fan cuts in okay, etc, etc…
Cheers.
Steve
1983 Golf Gti
Cheers,
Steve
and i am guessing this is the problem? I do indeed have a level sensor, i am guessing again this is the VDO thing and two wire plug on the header tank.
Now to find a number 43 relay……
The relay plugs in next to number 33 at the top see here - http://www.flickr.com/photos/steviobee/4026463000
Is it wired in the fusebox already or would it have to be altered? Sounds like a useful thing to have.
~Madferret
Mk1 1457cc 5door GX '83
At 20?C - approximately 1000 ohms
At 60?C - approximately 250 ohms
At 100?C - approximately 75 ohms
Lee - thats what mine used to do sometimes, i had a loose wire of about one strand left, so have soldered the cable back onto the connector at the sender unit in the engine bay, i guess you might want to check the relay too (if you got one) and maybe give the connector a wiggle at the back of the gauges, mine needs it sometimes to get the dials working properly.
Cheers,
Steve
Any ideas??
Could it be in moving the wire you inadvertantly stopping the short? In which case it'll be shorting on the bodywork somewhere.
~Madferret
