Temp Guage Problem
(In Topic #79822)
Temp Guage Problem
J 8)
first try making sure the crimp on the wire to the sender has a good connection, it also needs to earth through the body of the sender so also try to see if the pipe it screws into has a clean face so it gets a good contact.
you could also try earthing the wire that goes to the sender, this should swing the meter all the way over to the right I think. if the gauge inside doesn't move when you do this I'd guess it's either a broken wire or possibly in the gauge cluster itself, possibly somewhere like the voltage regulater - do all of the other gauges etc work? I think a faulty voltage regulater takes out a few other circuits but I can't remember what, might be fuel gauge? :dontknow:
could even be the wrong sender though? I don't know if they're the same on all engines or not?
hope this helps!
tim
'81 gti
