Switched ignition live feed to radio?
(In Topic #157076)
Cheers,
Matt
'83 1.3 Golf Driver GT - Project thread
Instagram - matt.semp
However, there should also be a standard radio loom providing it hasn't been cut out. Mines permanent live, but it's up to you I guess. Just like the idea of being able to be working on the car, or washing it or something, and be able to listen to the radio without the ignition on.
I wouldn't have thought the radio would use any battery if it is off.
There should be a connector in behind the radio.
Life Member
Here are a coue of photos to help you.
Dan
1989 helio\'s blue clipper
yours must be missing
Life Member
Re the permanent live, I've changed to the old style 'twisty knob' radio so no need for one. You are right there though.
you better check you have the big round hole in the door and body first.
I wouldnt want to drill that hole out
top tip for making small holes bigger with holesaw: (cant take credit for this one though!)
these are the holes which i assume are standard? but not sure what the larger hole on the door is for?
big square hole I have no idea, maybe its just part of the pressing or for ventilation or whatever. certainly nothing that should be fitted in it I dont think
I think that one is going to be too big anyway as I got one off a scirocco in the past which was same size as mk2 golf iirc
