Starter Motor removal on 1.5 1982 Auto
(In Topic #79372)
The procedure is in Haynes, albeit briefly so note the following:
Definately follow their tip of disconnecting the R/H driveshaft - you'll need a star shaped key to go on a ratchet to remove the bolts
You'll then need to remove the heat cover from the starter - one end has a bolt that's easy to remove but the other has a large jubilee clip which you will struggle to get a screwdriver to, I used an 'L' shaped bit of metal to undo it
Beware that once you take the 3 bolts holding the starter to the gearbox you'll need to support it whilst disconnecting the 2 wires that go to the top of the solenoid. As one of these goes straight to the battery it's worth disconnecting the battery to avoid sparks! 8O
Took me 5 hrs of arm aching graft so good luck :y:
Ian
'89 Clipper Auto and '92 GTI Cabby
