Starter motor problem
(In Topic #119621)
I thought it was an ignition switch problem so i bought a new one but it made no difference, the problem was still there. Ive since fitted 1 aftermarket and 2 VAG switches but the problem to no avail. I was then told it possibly an ignition barrel problem, so ive replaced that, and it made no difference. I then replaced the starter motor, even managed to get hold of a reconditioned VAG motor, fitted it and…… still happening, although the car does start much quicker now.
Ive since checked the wiring that goes down to the starter motor (the one with the spade connector that i have to remove before starting) and there is a permanent feed going to the wire. Obviously, there shouldnt be a permament feed going to this wire, it should only get power once im turning the key from stage 1 to stage 2.
My question is, why is there a permanent feed going to this wire, and what could be causing it? Is there a starter motor relay someplace?
I would greatly appreciate some help with this as its really beginning to get on my nerves
Might help 'til someone else can reply.
Can anyone else shed some light on my problem?
1: how many wires are going to your starter?
2: Does your Thermotime switch have a permanent feed to it? red with black wire to battery earth
3: Does it try to turn over with the fuel pump relay fitted?
Have you wired , sorry to ask , correctly the ignition switch
should be numbers and letters on back the switch
30 = red
15 = black
50 = red black x2 [joined]
x = yellow black
p = grey
30= battery live supply
15= power supply [ignition on]
50= starter solenoid and ignition power [cranking]
x= spare ? Goes to wiper switch ?
p= parking light switch
oh, and iirc the red/black wire on starter has a plug in the engine bay somewhere, check that too!
