Speedometer Cable
(In Topic #72483)
Speedometer Cable
I started getting a few problems with a jumpy speedo needle, looking through the old forum it looks like it could be related to the cable. This only seems to happen on motorways if I go above 60/70 and then the trip distance and the odometer stop as well. Next time I start the car they both work again. Is this all to do with the cable, or is there something else?
Jon.
i had the same problem with mine, i am talking about my 1.8 GTI
In order to find out what was causing it i first started at the gear box and replaced the plastic drive , cost a few pounds from my main VW dealer . Problem still existed so i then replaced the speedo cable , about ?35.00 .
Still the same , unfortunatly it turned out to be the speedo head , [although mine jumped and used to get stuck ] i was lucky to get a complete one from eBay for ?55.00 problem sorted .
If you start with the cheapest first the solution could be cheap .
Cheers Chudd….
If the hole is still square then cable should (?) fix it!
