spark!
(In Topic #89208)
spark!
does fittin a bigger coil increase spark?
rebuild in progress....
no
why
because i said so :wink:
thatll do me!!
ill be more precise
was off a 5 cyl audi
cant use a multimeter but set it to ohms or somethin read 145, my old one 109
as soon as i wired her up my engine got alot quieter, also gettin less back popping as i drop from high revs in 2nd/3rd, maybe less unused fuel??
plugs are good ht leads good as is dizzy and rotor (as always :wink: )
so why ??
ill be more precise
so why ??
ok you got me
i dont know
theres a good way of getting a huge spark tho
1x electrical screwdriver
1x household fuse box
1x wooders
left for ten minutes to play = one mahussive spark half a screwdriver and no wooders
did that awnser your question
i dont know
1x wooders
no
ive put this up twice , both here and cgti and no one knows, tis quite frankly doin me ed in!, all i want to know is how to get a bigger spark really
where is wooders, does he sleep on tuesdays or somethin??
the spark is all to do with dwell and discharge
so if the coil cause a the dwell to increase then yes it will have a bigger spark but it will also burn out the plus and leads quicker
discharge time is how quickly the spark comes and goes :wink:
christ its like pullin teeth sometimes….
ta :wink:
ta :wink:
you adjusted the fuel pressure yet that will have the desired effect 8)
haha, mind reader
been researchin that for last 2 days lmfao
its all about the shim you know paul_c knows waht to do :wink:
he does :notworthy:
his 2l better be a bit quicker tho eh :wink:
back on the subject
if the audi coil extended the discharge time, which i suspect, would that allow room for some timing play?
his 2l is quicker on the track than my cab and ive got 4 valves more and a turbo and also a shed load more weight
tis a symbolic struggle tween cab and tinnie
any 20vt tintops on here?
yes the dwell and discharge time should effect the timing in theory i believe
guess theres only one way to find out get a timing light out and seewhat the timing does with the standard and then the audi :wink:
need to think of a hoax thread to start in mk1 chat i reckon the coil one is good increase bhp by say 10bhp
audi plugs would be set for less charge being off a 5cyl engine, my ones set for less charge,
which spark plugs?
and ht leads
which spark plugs?
and ht leads
im rollin roadin for me bday
we shall see!
we shall see!
